Much needed feature request: Add "By Table" option to channel setup for calibrating non-linear transducers
I deal a lot with calibrating custom built load cells which, often due to part geometry, is non-linear through zero.
Currently there is no easy way to accurately define a sensor's cal values unless it's linear or "assumed" linear through zero.
I know the workaround is to define the sensor in the sensor database and choose table or polynom etc. but this doesn't offer the real-time "from average" buttons like the By Two Points option does.
How about next to the By Two Points and By Function, add a By Table option which would work exactly like By Two Points, but with more points.
OR....
expand on the existing By Two Points option by adding a "+" to add additional points. The goal is being able to have that From Average button as you increment through your target loads in real time.
This is piggybacking on a similar discussion from a while ago
https://forum.dewesoft.com/software-discussions/dewesoft-software/how-to-scale-non-linear-transducers
Dear Lemmy,
I would like to inform you that this feature request was added to the wish list. We will notify you when there is an update on this request.
Best Regards.
Rok
@Rok Kmetič
Please notify me as well! I need this exact function! Would simplify our calibration very much.
