How to scale non-linear transducers?
  • How to scale non-linear transducers?
Lemmy Atom
Posted on 09.06.2021 20:22
Hi
I have a load transducer which is non-linear through zero (i.e. its sensitivity is different for compression than it is for tension). If I scale it as a By two points calibration I get a very large offset at zero. If I scale it by function it linearizes my "curve" and the end points are inaccurate.
I use other software (MTS FlexTest) that features a Gain/Delta-K function which allows you to have separate sensitivities for tension and compression; Gain for the positive end and Delta-K for the negative end of the signal.
Thank you!
Posted on 16.06.2021 14:05
Hi Lemmy,
If you define the sensor into the sensor data base, you will have more scaling types on option:
Let me know if this method suits for your needs.
Best regards.
