Coneectring 3-wire pressure sensor to DEWE 43A
Karansinh Kurane
Posted on 08.05.2023 23:30
I am using 30psi Pressure sensor and having issue with connection:
Sensor Detail:
Specifications:
Material: Stainless steel
Voltage: DC 5V
Pressure: 30 psi
Thread Type: 1/8" NPT
30 psi
Input: 030 psi
Output: 0.5V~4.5V linear voltage output. 0 psi outputs 0.5V, 15psi outputs 2.5V, 30 psi outputs 4.5V.
Accuracy: within 2% of reading (full scale).
Thread: 1/8"27 NPT.
Wiring Connector: Water sealed quick disconnect. Mating connector is included.
Wiring: Red for +5V; Black for ground; Blue for signal output.
I am using following connections:
The sensor has following connector:
Primoz Lapi
Posted on 15.05.2023 10:05
DEWE 43 has fixed +/-5V excitation. In this case, we would suggest this wiring:
SNS+ in EXC + = +5V sensor supply (red)
GND, IN- and GND together. (black)
IN+ signal input (blue)
SNS- and EXC- can stay disconnected.
Karansinh Kurane
Posted on 12.07.2023 23:51
I am using a 3 pin connector and am still not able to read the pressure value
Regards,
karansinh Kurane
Primoz Lapi
Posted on 13.07.2023 08:44
could you send us the sensor datasheet?
Karansinh Kurane
Posted on 13.07.2023 19:49
Please find attached Data sheet
Sensor: MT01
Voltage: 0.5V to 4.5V
Pressure: 0 bar to 250bar
Rok Kmetič
Posted on 14.07.2023 14:49
Dear Karansinh,
I have replied on this topic: https://forum.dewesoft.com/hardware-discussions/dewesoft-instruments/connecting-pressure-sensor-to-dewe43a
Please let us know if the new wiring diagram helped.
Best regards.
Rok
