Connecting Pressure Sensor to DEWE43A
Karansinh Kurane
Posted on 13.07.2023 01:45
I am trying to connect STW pressure sensor on DEWE43a.
Attached sensor information
I am using the same connection mentioned in one other forum topic.
Also I am using Differential input type
but i am not seeing any pressure change.
Would appreciate any help.
Rok Kmetič
Posted on 14.07.2023 14:47
Dear Karansinh,
I have checked the attached drawing and basically, it is done correctly but the pins can be confused because the lines are drawn over the incorrect ones.
Please recheck the wiring:
If you measure between Pin1 and Pin4 you should get 5V of excitation. The SNS line regulates the excitation so it is a stable 5V.
Please note that the +/- 5V on Dewe-43 has a 70mA current limit:
Rok
signup
for
free
account
