Virtual machine - no device detected
Francesco Antonio Miccoli
Posted on 04.03.2024 10:50
Hello everyone!
First of all I am sorry if this is not the right forum for this question but I was not sure where to ask.
I am currently running Dewesoft X 2024.1 on Windows 11 emulated via Parallels on an M1 Pro MacBook Pro. The software installed without any warning and runs smoothly (I can do data analysis and use all functions without any issue). The only big problem I have is that I am not able to connect any DAQ to it. It just does not seen any device connected. Keep in mind that all needed options (so adapter passthrough and network sharing) are enabled in the virtual machine settings.
I know that Dewesoft X does not natively support emulation but it seems weird that everything works fine but I can't connect to the DAQ. Do you have any idea why this might be? What could I try? Thanks in advance
Pika Kreča Šmid
Posted on 05.03.2024 10:17
Dear Francesco,
We do not test our software on Windows, emulated via Parallels on MacBook devices, so I cannot give you a definite answer to your question, but it looks like there's an issue related to Parallels.
You have mentioned using DAQ devices, could you please let us know which devices you are working with? Are you using USB devices or EtherCat devices?
Can you confirm that the devices are recognized in Parallels?
Is the launcher working in the virtual machine?
Have you tried running Dewesoft as an administrator?
Pika
Posted on 05.03.2024 11:09
@Pika Kreča Šmid
Thank you for the reply. I am using Iolite modules with ethercat. No, I do not see the client running when the application is open. How would I solve this? Thank you
Pika Kreča Šmid
Posted on 05.03.2024 12:28
Dear Francesco,
you could try taking a look at the Iolite manual's troubleshooting section and our solution if the EtherCAT devices are not detected.
You should specifically pay attention to whether or not Ethercat DAQ Filter drivers are installed on your virtual machine, and force DewesoftX to run as admin.
The 2nd step when it comes to EtherCAT devices are not recognized manual is supposedly slightly different for paralleled systems. There, you should go to USB 10/100/1000 LAN settings, under "hardware" and change the "Automatic" configuration to "Manual". Then, set the speed to Base 1000baseT, Full Duplex, and Standard MTU. Press "OK" and then see if the Iolite is seen by Dewesoft.
Pika
Posted on 05.03.2024 19:00
@Pika Kreča Šmid
It appears Ethercat DAQ Filter is not installed on the virtual machine. When trying to install I get the following. It may be due to the fact that windows ARM is running and translation to x64 is used.
Pika Kreča Šmid
Posted on 06.03.2024 08:15
Dear Francesco,
I am sorry to hear the issue wasn't resolved.
It looks like this is an issue with the computer/virtual machine not being able to install the drivers, so there is not much we can do from Dewesoft's point of view. We also do not have much experience when it comes to using Parallels, so it is rather difficult to give you any concrete advice.
Were any EtherCAT DAQ filter drivers installed before you've installed this latest version?
Since you are installing the drivers as a separate component, I would suggest you check out our solution: Manual EtherCAT DAQ driver installation, and try to re-install the drivers from our webpage. Please do note that you should uninstall the previously installed EtherCAT DAQ drivers before installing the new drivers.
We did have a client that has successfully resolved the error code: 0x0 issue, however, they were using a Windows computer, not a virtual machine, so I am not sure if any of their troubleshooting will help in your case. -> The client was running Windows 11 Pro with Microsoft 2013 C++ Redistributable installed.
The basic steps they took were:
  • Installing the drivers as an administrator: Try and right-click on the installer and select "Run as Administrator."
  • Check and disable any IT permissions and firewalls
  • Making sure that DewesoftX's or the Ethercat DAQ filter was installed in the C:/ driver
  • checking for windows updates (you can track down your specific device manufacturer by going into Network Connections or Device Manager.)
What actually worked for the client was going to their Ethernet adapter properties and pressing the ''install...'' button.
Then they selected the ''Service'' option and pressed ''Add''
They found and selected the EthercatDAQ Filter
They did this for each of their network adapters, and then connected their device over DewesoftX.
If you have one available, you could also try connecting the device to the computer via a USB to RJ45 adapter and see if this resolves anything.
Pika
Gary Floyd
Posted on 26.06.2024 06:26
The ethercat driver won’t be able to be installed as you’re already emulating the network Ethernet card in parallels. You should be able to pass through a usb to ethernet adapter and then install the ethercat adapter with the usb Ethernet driver. Other option is WiFi for the parallels interface and then use the Ethernet.
dewesoft runs quite well being emulated, actually much more stable than in native windows.
VM KHOI
Posted on 25.12.2025 11:00
Halo Pika Kreča Šmid,
I have similar issue, but i use Sirius XHS device and it using USB connect port.
I set the connect usb port to Win but i can't find the device in the DEWESoft App
Do you have solution for my issue?
My device is Macbook M1 pro and application version is newest.
Pika Kreča Šmid
Posted on 29.12.2025 11:31
Dear VM KHOI,
I understand that you are trying to connect our SIRIUS-XHS device to a Macbook M1 pro using the standard USB connection.
In the past we've seen where the USB driver doesn't install on Parallels installations. You could attempt to install the driver from our Downloads webpage, however, since the Macbook's Apple Silicon CPU is based on the ARM architecture, it's likely that our drivers won't be compatible with the processor on your computer.
We do have better experience with XHS connection over the GLAN port (Connection over EtherNET), so we would recommend you try this kind of connection instead.
Pika
VM KHOI
Posted on 10.01.2026 04:27
Halo Pika,
I install the driver and manual update the driver but i can't find the driver
Because i have only SIRIUS-XHS, Can you help me 1 way to connect this device to my PC?
Pika Kreča Šmid
Posted on 12.01.2026 08:43
Dear VM KHOI,
I'm sorry to hear that you weren't able to establish a USB connection between the Sirius-XHS and your Macbook M1 pro. It looks like the driver isn't compatible with your processor, as the Apple Silicon is based on the ARM architecture, and our drivers are not supported on it. You could try connecting the XHS over EtherNET, if you get better results with this connection.
I would like to note that officially, only DewesoftX is able to run on an ARM processor  (in emulation mode) but drivers (USB and EtherCAT) are missing, so you most likely won't be able to establish a connection between your AMR-based laptop and the Sirius-XHS device.
We do have a feature request to support ARM-based processors, so we will link this thread to the request, but implementing this is currently not in a short-term plan.
VM KHOI
Posted on 19.08.2026 09:48
Good day DEWESoft Team,
I just buy the KRYPTONi module with Ethernet Cable and i am trying to connect it to Software.
In the sofrware, I canot find DEWESoft device.
Please let me know why i can not connect.
