Zero select sensors at the start of measurement
  • Zero select sensors at the start of measurement
Tristan Jones
Posted on 09.06.2023 06:21
Is there another way either in measurement mode or in sequencer to auto zero select sensor groups at the start of measurement.
Yes i am aware of the zero button beside the design menu bar but im looking for something that's more production floor suitable.
I realise this can be done in maths ( albeit it's more difficult than it should be, at least with the approach i took). Do you have a good way to do this with maths only? Ideally take the first 0.5 seconds of data and set zero based on that.
Thanks
Primoz Lapi
Posted on 12.06.2023 14:35
if you would like to zero with an average of 0,5 seconds, you could use this workaround.
  1. Create time channel as trigger channel for basic statistics
  2. Add basic statistics with the same settings as are on the picture below and check all the channels that need to be zeroed
  3. Create formula for each channel (Example for first analog channel 'AI1'-'AI1/AVE')
Tristan Jones
Posted on 19.06.2023 14:05
Thanks for your assistance
