what some affect when set scalling Temp. from K to celsius
vafara
Member
Member
Posted on 04.02.2009 07:08
I set Temperature channel for Celsius and store data this is example and change scaling for Celsius question what different to data when I use Celsius unit and Kelvin unit ? if different what affect to data when Temperature is change unit to Celsius and Kelvin ? etc. heat release Ti TQ
vafara
Member
Member
Posted on 04.02.2009 07:18
add becuase
I store data with Celsius unit it will be make me to collage wrong data.
Thank you.
vafara
Dewesoft Administrator
Member
Member
Posted on 04.02.2009 09:11
Temperature channel can't be used directly in CA. You can not use this channel directly on cylinder instead of pressure channel. In that case TI and TQ will have no meaning. You can only use it as additional channel. In this case it is your choice what unit will you use for that channel, because no math from CA is done on additonal channels.
If there is still something unclear, please send me more screenshots of how you setup CA and where to you put that temperature channel.
Tilen.
vafara
Member
Member
Posted on 04.02.2009 21:28
I'm clear.
I don't set Temperature channel in Engine tab I set for pressure channel.
and in conbustion analysis tab I don't use Temperature channel.
Thank you again.
vafara
and I will delete my picture from my web server. if you like to use picture from topic "what some affect when set scalling Temp. from K to celsius" and "heat release not show" for this forum please coppy it before 20/02/2009
signup
for
free
account
