What if I don't know my expected measurement range?
  • What if I don't know my expected measurement range?
Lemmie Atom
Posted on 02.10.2019 20:14
New-ish user here.
What do you recommend doing if I don't know what my measurement range is expected to be?
For instance, I was taking impact data with accelerometers and "expected" to see up to 5 Gs, so I set the measurement range within that value in the channel sensor settings. During the actual test we got up to 35 G's! I would not have noticed an issue but happened to see the OVL warning in the upper corner of the screen. That's when I went in and selected a higher measurement range.
But had I not noticed I would've clipped my data. What should I do in this case, when I don't know what my expected range will be?
Thanks
Posted on 03.10.2019 17:30
can I ask what is the range of the accelerometer and which amplifier is used?
If you are using Sirius, you can enable high range and dual core mode.
https://www.youtube.com/watch?time_continue=59&v=mzNyTn3W42s
Lemmy Atom
Posted on 03.10.2019 19:10
@DEWESoft Support
30G accelerometer
The settings below show the measurement range after it had been changed it.
Posted on 04.10.2019 13:38
From the accelerometer specification sheet it looks like you reached the accelerometer limit which is 30g. Do you have the option to use different accelerometer with higher range?
Can I ask why are you using the bridge measurement type? From the specification it looks like you should be using a normal voltage measurement type and differential input type.
Lemmy Atom
Posted on 10.10.2019 18:16
@DEWESoft Support
Yes, I understand that I exceeded the range of the accelerometer. Lets say I didn't though, the questions still remains. If I don't know what my measurement range is expected to be what should I set it to? I'm guessing it's okay to set a range one or two stages higher than "expected" due to the dual core feature?
Also, thanks for catching the use of a full bridge input type. That's a habit carried over from our old DAQ's where we treated everything like a full bridge. Do you think it affected the output of the accel? It passed a 2g rollover which is why it didn't raise any red flags for me.
I'll keep it in mind for next time.
Thank you
~EDIT~
I configured my accelerometer to a voltage measurement the way you've shown. I do not have the dual-core check box option.
Posted on 25.10.2019 09:38
From the screenshot that you have sent to us it looks like you have Sirius high speed which doesn't have the dual core option.
If you have the option I would suggest using a dual core Sirius which automatically switches between the ranges.
If ithis is not an option, I would suggest using highest range for test and then adjust range if needed.
