use a variable or a channel as the basis for a data file name
  • use a variable or a channel as the basis for a data file name
Matt Hanks
Posted on 16.01.2020 15:44
Hello, in the X3 SP9 release notes under the "Features, Improvements" section it says
"Store Engine
 - Added option to use a variable or a channel as the basis for a data file name"
I would love to be able to do this, but using X3 SP9 I don't see how to do this option. Is there a check box somewhere I'm missing?
Posted on 20.01.2020 11:26
Dear Matt,
with this exact additional feature you can now use Global data variables in the "Storing" option:
Regards,
Matt Hanks
Posted on 21.01.2020 17:39
@DEWESoft Support
The image does not show up for me. All I see is the file name and I don't see any way to view it or download it.
Posted on 22.01.2020 07:50
Dear Matt,
basically you can enter the "Unique ID" or "Name" of Global Variable, in the storing name box. You just need to put the name in quotation mark, similar as when you use variables in sequencer.
Regards
Matt Hanks
Posted on 22.01.2020 16:47
@DEWESoft Support
Is this only useful when using sequencer?
Matt Hanks
Posted on 22.01.2020 18:26
I figured it out. I can change it on the fly when in measure by using an "Input control" widget.
