Turn ON/OFF transmit messages/signals
Is it possible to add a button/control to the measurement screen to turn on/off a transmit message and or signal?
I know I can control these messages as to what they send, but when I am monitoring the canbus I want to turn off all the transmit messages otherwise I am disturbing the canbus. right now im turning off all the transmit messages by hand in the channel setup, so I was wondering can this be made easier?
thank you in advance,
Robert Valk
this can be done with the use of trigger for transmit. For every trigger, a message is transmitted. We have used a sine wave for triggering. Unfortunately, when the trigger is used for transmitting, the maximum update rate is the same as acquisition update rate (settings->performance) but it is limited to 150Hz.
In the attachment is also a short setup file as example.
