Trace resolution
nick arran
Posted on 29.07.2025 08:28
When showing a long duration of data, dewesoft shows an envelope (thick line between the min and max values recorded in a certain time) instead of the actual sample by sample data. When I zoom in, the true data is displayed.
The switch between showing full data and the envelope of the data occurs long before my PC's screen runs out of resolution. Is there any way to change the level of zoom at which the change from full data to envelope occurs? Ie can I force dewesoft to use the full (4k) resolution of my screen when showing data?
Full data
Zoom out (one click on -) = envelope
Pika Kreča Šmid
Posted on 30.07.2025 07:37
Dear Nick,
I can see that you are experiencing blobbing on Zoomed-out data on a Recorder widget. This blobbing is due to a multi level buffer structure, which is really well described in our FAQ article, Optimize sample buffers for best signal visualization.
To try and mitigate the issue, you can try enabling the Optimize sample buffers for best signal visualization checkbox, which can be found in Settings -> Advanced -> Performance, under the Memory dropdown menu.
Pika
nick arran
Posted on 04.08.2025 15:49
Thanks; that sorts out something that has irritated me for the last 10 years (or more!). Plots much improved.
Pika Kreča Šmid
Posted on 05.08.2025 05:19
Dear Nick,
thank you for the follow-up, I'm glad to hear the solution resolved the issues you were experiencing.
Pika
