Time to vector transform problem
I used the time to vector transform to get the average, maximum and minimum curves of torsion angle channel:
However, when I select the 2d Graph to show the diagrams I only see the values up to 360 degrees and not over the entire range I have defined in the setup:
How I can fix it?
Thank you very much!
Regards
Valerio
NVH Application Engineer
Dear Valerio,
please make sure that your reference angle signal has a range between 0 and 720 degrees.
I can see the same behavior in my datafile. The channel CNT0/Winkel has a range between 0 and 360 degrees.
That is why the results are shown only up to 360 degrees.
Jernej Sirk
Dear Jernej,
My reference angle has a range between 0 and 360 degrees.
Can I modify it in post-processing?
Dear Valerio,
Unfortunately, you cannot modify the range of an angle in post-processing.
There might be a workaround by using the XY recorder widget.
First, add the XY recorder widget.
On X axis, select angle from the counter sensor and on Y axis select the wanted quantity (torsion angle in your case).
Select Angle based x-y type and 0...360° option. Then you can define the number of wanted periods.
Jernej Sirk
Dear Jerney,
Thanks for your support.
This option works effectively, however I can't use the time to vector transform because I recorded data with reference angle range between 0 and 360 degrees.
Regards
Valerio
