Time-stamped Ethernet Data
Pete Pickering
Posted on 08.08.2016 16:12
I have a data stream coming in via Ethernet Receiver, which contains a timestamp and several values.
As the data does not arrive very well timed, is there a means to align the data with Dewesoft timebase using the timestamp?
Posted on 10.08.2016 09:35
unfortunately, at the moment this is not possible.
Since ethernet cards works in bursts, it is normal that data is not received at regular intervals. Timestamp is currently received from the ethernet frame timestamp (generated by NIC), which is later soft synchronized with clock provider, so that you don't have any long term drift.
signup
for
free
account
