Time selector wiht fixed values
Hallo,
in recorded data, I only want to export a specific area. I manually set the cursor to the start of the event. In the time selector I use the button 'set from cursor' to set the time to 0. With the 2 other inputs I set a pretime and the shown time.
Everything works as desired.
When I switch to the next event via the Time overview box, I want to generate the same section again after I have repositioned the cursor.
However, the values in the time selection have changed and must be re-entered manually.
Is it possible to fix the input fields with fixed values in the time selector?
Best regards
Michael Beck
Dear Michael,
thank you for reaching out to us. The time selector is used for selecting time, so the relative to measurement time will be based on the time in the data file - you can reset this by pressing Set from cursor or manually enter the Offset time. The shown time is retained when moving the zoomed region by dragging the box in Time selector window.
Would you please be so kind and explain in more detail what you would like to achieve.
Kind regards.
I apologize for the late reply.
The question was whether the values marked in yellow could be set as default values. This would minimize manual modification steps for recurring measurements.
I think this won't be possible.
Dear Michael,
the Zeit anzeigen option will not change if you will move the zoomed region. However the relative zur Messung time will change depending on the Relative Zeitoffset that you will select from cursor so this can not stay constant.
Kind regards,
