support PCIe-6363?
lv
uroš lulik
Posted on 07.05.2010 17:25
There is some ini file which should be modified to support new cards.
Modified NI_MXCards.ini for PCIe-6363 can be found on this link:
http://www.dewesoft.org/download/section/7
Launch Dewesoft7 go to Settings->Global setup->Folders, you will see the path to System folder, open this folder and save NI_MXCards.ini from attached link into this folder.
Please inform us if PCIe-6363 is working with this ini file!!
Best regards!
lv
Posted on 10.05.2010 03:10
hi,
I'm sorry to tell you that it doesn't work.
I have tried to put the ini file in several folders. it's all failed.
Dewesoft7 has recognized the daqmx version is 9.0, but doesn't recognize the device. I have tried this for dewesoft6.6.5, it's also unsuccessful.
The OS is windows 7. Does it have any influence?
Waiting for your help.
Best regards.
lv
Posted on 10.05.2010 06:24
hi,
I am so glad to tell you it works!
After I changed the dewesoft.exe to latest DEWEsoft701_b54, it works just as normal.
Then, there is another question needing your help. How to make it work for dewesoft665?
thanks a lot.
best regards.
uroš lulik
Posted on 10.05.2010 08:36
It is only possible in DEWESoft7.0 or newer to add support for new hardware. DEWESoft665 does not support adding new hardware.
Best regards!
signup
for
free
account
