Summary data from Endurance testing
Dear Team,
I am Ignatius from Brakes India Pvt Ltd, working as a Manager in testing Department. I have an issue related to exporting Max, Min and Average values from the Endurance testing which has almost 5000 files. What I need is, there should be a separate file continuously capturing the summary of the parameters configured for each file based on the trigger set. Now I am finding it difficult to get the summary of the whole 5000 tests at once and see the overall trend of the summary like Max, Min and Average values.
Can Dewesoft team suggests a suitable method to get the summary data.
Thanks in Advance
Regards,
X Ignatius
Dear Ignatius,
In case you recorded a multifile, Dewesoft offers a Multifile export function, which can be utilized for exporting Min, Max, Average and RMS values. To achieve this, simply employ the multifile export feature and configure the data export option to Reduced data and check the boxes for Average, Min, and Max. For a detailed guide on Multifile export, you can refer to the manual.
If you require additional mathematical or statistical values, I recommend importing one of the files and applying the Math -> Formula or Statistics function to calculate the desired values. Subsequently, adjust the export settings to include only the Formula or Statistics channels for export and save the file changes. Then you can select all the other files and use the Apply action function. Finally, utilize the Multifile export function to complete the process. For a detailed guide on Apply action function, you can refer to the manual.
Eva
