Summary data export
Hello.
I have logged data "fast on trigger, slow otherwise" , usually 20 triggered events per file. I have set up a basic stat. channel to return Max and Min of an Input channel during the fast storing sections.
What is the best way to export a single data point for the max and min per calculation?
Thanks!
Dear Michael,
we would need some additional information on this topic to support you.
You want to export one value at once? And not all the Max values that were recorded in the data file? Or you want to export all the points in the data file?
Regards
@Eva Kalšek
Hello Eva, Thanks for the assistance.
I would like to export one value from the channels MAX and MIN for each fast logging event. So every time the acquisition stops storing fast (at each E marker) can I export the current value of each channel as one data point, then at the next E marker the current value of the channels? So I get a brief summary of the data? This would be the equivalent of subtotals in a spreadsheet. I am looking to see if I can process in Dewesoft directly.
Michael.
I have got a solution. We were using excel or csv export.
Using a .txt export gives the data I was looking for.
Michael.
Dear Michael,
thank you for the update.
If you need any additional help, let us know.
Regards
