Squence operation - Close DEWESoft at end of sequence process
  • Squence operation - Close DEWESoft at end of sequence process
Michael Macias
Posted on 16.05.2024 20:42
I created a sequence process that I would like to have DEWESoft close at the end of the process. I have not been able to find this action in the list. Is it possible for the sequence to close DEWESoft at the end of the sequence process? If possible, which process step do I need to add to the end of my sequence.
Nejc Ucman
Posted on 17.05.2024 08:54
Dear Michael,
thank you for contacting us. It is indeed possible to close DewesoftX application to close after the sequence has finished. You can use the "CloseApp" action block. In the "AppName" parameter just write "dewesoft" and the application will close.
Example:
Nejc Ucman
