Speed Integration for Distance Traveled
Without having the Brake Test add-in or plug-in is there a way to generate distance traveled from velocity? I recognize the integration ability but not sure how to set time references. Any help appreciated.
Dear Scott,
Yes, you can generate the distance traveled from velocity in the Math Module by using the Time Integration function. In the setup for the operation, you can select "Integration" and then choose your velocity signal as the channel. For more detailed information on integration, you can refer to the manual.
Regarding time references, you have the option to either integrate the entire signal or just a zoomed region. For example, if you zoom in on the time axis between 5 and 15 seconds, and select "Recalculate," it will integrate only that specific 10-second interval.
I hope this helps! If you have any further questions or need additional assistance, feel free to reach out.
Best regards, Hana
