Some values are showing as "Not Stored" even if they are saved
  • Some values are showing as "Not Stored" even if they are saved
David Dieffenthaler
Posted on 09.03.2022 15:21
Even though I configure the software to store all values that I needed, when I reopen the recorded files with DewesoftX, some values appear as not store
In order to force the software to display something, I have to "trick" the formulas by adding +0 or something to force the auto calculate. However this trick does not work for the values which appears as missing that were recorded with the Power Module.
Primoz Lapi
Posted on 15.03.2022 10:54
from the screenshot "MathAreStored.JPG" it looks like some channels have 0Hz sampling rate.
We can also check the data file if you can share it with us.
Steven Hardy
Posted on 01.03.2023 10:12
HI. Using version 2023.1 I'm now getting 'Not Stored' on the Date and Time displays 'Digital Meter Widget' on a typical screen - when I've turned off the store on a completely unrelated channel!?
