Setting "Time selector" via Sequencer
is there any way to set the "Time selector" parameter via Sequencer. What i need is to set the Trigger to 0s and zoom the data for printing!
Thank you very much!
Florian
Dear Florian,
you can try to use the action block shown on the picture below:
I hope it is useful for you.
Best Regards.
Rok
Hi Rok,
thank you for your reply. But this selects only the Section which would be deisplayed.
Trigger-Time ist 4.37495s, i set StartPos to 4.37495s and EndPos to 7.37495s. So this appears:
What i need is, this:
I now generated a Math-Cahannel with my own x-Axis and put it into a x/y Recorder. Only thing is that i can only display that in Analysis mode because Math-Channels has to be calculated after measurement. And x/y Recorder has no transparent Background so i can only display it in black.
Best Regards,
Florian
The Problem now is, that i can not recalculate the Math Channels in Analysis mode. I can not set the Math channels as offline so i can calculate it in Analyze mode. I thougth in older versions of DeweSoft this was possilbe. Is there another way to do this?
Ok,
if found how to set the Channel Offline, i had to make the column visible in math channel view like described here:
https://manual.dewesoft.com/x/setupmodule/outputchannellist
If i put the x/y recoder into a Report Screen the Background is white!
So this is my solution actually!
Best Regards,
Florian
Dear Florian,
Awesome, I'm glad to hear that you were able to sort it out, and thanks for letting me know.
Best regards.
Rok Kmetič
