Serial connection speed negotiation
Gary Floyd
Posted on 20.04.2023 13:49
I have a rs232 device that starts boots up at 9600 bps and then requires a command be sent to switch to higher rates. Once that command is sent the device will then switch to the higher baud rate and start transmitting again. The serial comm add-in does not appear to support this. I was tempted to try using the sequencer to connect to the device, switch the baud and then when dewesoft switches to measurement mode and tries to connect to the device it would be talking at the high rate. So I was wondering what the recommended method for this would be as it’s pretty common scenario for serial devices?
Primoz Lapi
Posted on 21.04.2023 14:26
we don't have this option at the moment. I have added it to the wish list and we will send you an email if there will be any updates.
signup
for
free
account
