Sequencer Test Cases - How to Run automatically
I normally run sequence files by having my users double click on the .dxt file in dewesoft. The sequence would guide the user through the process, setup variables, save files, etc. I moved my main sequence into the first test case but when .dxt file is double clicked nothing is run as the sequence is trying to run main sequence. If I manually run the test case it will go through the sequence as expected and run all the test cases. Is there a way to run test cases instead of the main or tell dewesoft to run test cases after running the main sequence.
Gary
Hi Gary,
If you would like to run test cases you should leave Main sequence empty. Then double click will run case by case subsequently.
Best regards
This is what I did (left main empty) copied the contents to the first test case. Double clicking on the .dxt just brought me back to main. I will try again and see what happens.
Ok, that appears to work fine as long as the main sequence is empty. Thanks for the help.
