Sequencer multi displays in measure.
  • Sequencer multi displays in measure.
Jacob Fern
Posted on 05.08.2022 13:32
Is there a way to keep the portion of the toolbar active that holds the various built displays available while in sequencer, while removing the upper portion?
Ideally, I would like to keep just the portion in red, but If I need to keep the entire toolbar that is in blue that is acceptable as well.
Damien Lajarrige
Posted on 08.08.2022 15:34
Hello dear Jacob,
The sequencer can execute some DewesoftX actions. In the Sequencer settings there is an option to show or hide the toolbar.
These sequencer settings can also hide the main toolbar, the control toolbar, the sequence actions buttons...
With the Input control we can select a screen display by clicking on it. In default setup the user input is at the top of the main screen where you can see the location and the name of the data file, the sampling rate and you can use it for several Dewesoft actions.
Add Input control widget, select Dewesoft action and Screen select. On button text, write the name of the display. It’s possible to load an image, this one will be instead of the text. Please notice that the widgets are independent and changing a setting on one widget needs to be applied to other widgets. So I would suggest that one widget is created and copied to the rest of the displays.
You can find the setup file and a simple sequencer in attachment.
Kind regards,
Damien.
Fabian Schnurre
Posted on 27.11.2024 13:29
Hello Damien, thank you very much! How to switch displays in analyze/review mode though? Greetings!
Matic Pevec
Posted on 28.11.2024 10:03
Dear Fabian,
Switching displays as declared above is possible only in Measure mode not in Analyze mode. We have in plan to improve and unify displays switching in the future.
We will let you know when this is done.
Until then I cannot recommend any workaround.
Matic Pevec
Posted on 16.04.2025 04:21
We would like to inform you that "Option to swap channels on widgets with next or previous of assigned ones" was implemented in the new DewesoftX development version 2025/3/DEV-250408 which is already available on Download Center on this link: https://dewesoft.com/download/dewesoftx-development-preview.
To update directly from DewesoftX, simply click on "Check for updates" and follow the installer instructions.
