Sequencer - How to copy a global variable in a fonction generator in sequencer.
  • Sequencer - How to copy a global variable in a fonction generator in sequencer.
Damien Lajarrige
Posted on 07.03.2024 14:46
Hello Dewesoft team, I hope you are well since my internship.
I am using Dewesoft to control a vibrating pot that I control with the generator function. However, I'm stuck.
We want to perform a sinus vibration and perform a frequency sweep to refocus our sinus excitation frequency accross the time of a vib test.
To do this, I use a sequence with two setup files.
A first setup file allows me to create my vibration with a sinus at a frequency defined according to the resonance frequency of my equipment.
A second setup file allows me to perform a frequency sweep around this frequency in order to recalibrate my excitation frequency after a vibration phase.
I use the function generator for this, and I get the value of the frequency for which the acceleration is the highest which I store as a global variable. I then want to implement this variable in my function generator of my first setup in order to create my vibration with this new resonance frequency.
The problem is that I cannot implement this variable in my function generator, I get the following error; "Warning (Calculation): No samples acquired".
Could you tell me if what I want to do is feasible? And if yes, how ?
I am also attaching my 3 files as attachments.
Thanking you in advance,
Damien LAJARRIGE
Damien Lajarrige
Posted on 07.03.2024 18:31
I saw that my HPV_vib.dxs file was wrong, here in the .zip are the 3 correct files.
Below, some screen shots et recording to see better what is going on during the sequence execution.
When I start the sequence, with sinus.
When I do the sinus sweep to find the resonance frequency.
The error while I want to save the value in global variable.
Thanks for helping,
Best regards.
Damien
Damien Lajarrige
Posted on 08.03.2024 16:53
I solved my issue.
I can now restart my generation of fixed sine with the resonance frequency found by my sweep of my second setup.
I think my problem was that my setup files had not been updated in my sequence and therefore could not read/edit my global variable.
Thank you all the same, wishing you the best.
Rok Kmetič
Posted on 11.03.2024 15:01
Dear Damien,
Great to hear from you!
Awesome, I'm glad to hear that you were able to sort it out, and thanks for letting me know.
Best regards.
Rok
