Sequencer - automatic PDF print without a dialogue
Is there a way to implement automatic printing of a report display in sequencer? What I mean by automatic way, is that the display is printed by giving it a filename, and without showing print dialogue?
Thank you.
Dear Dan,
For automatic printing I can suggest 7-PDF program which enables you do disable pop-up dialogs --> https://www.7-pdf.com/products/pdf-printer
Then using the following sequence will print the report to the PDF file and use the filename as DXD file.
I hope this helps.
thank you for providing great step-by-step information on how to implemented automated printing. I tested it on my PC and it works very well.
It helped me implement automatic PDF generation from the sequencer.
Two additional steps are needed to be added in order to make it work as I intended:
- in Windows settings the 7PDF printer needs to be set as the default printer
- I couldn't figure out how to pass a filename from Dewesoft to 7PDF to make the PDF name different. Instead I'm printing the PDF with the same name and changing the name in the sequencer with File manager block -> operation type Rename file.
Besides that, all works fine now.
Thanks again for your help.
Dear Dan,
Correct, I forgot to mention that the 7-PDF should be set as default in Windows settings.
Regarding the naming I use the DXD naming for PDF as well. Please find attached the video on how this can be done.
I see. I was making a mistake by putting a fixed name to 7-PDF filename. It didn't take it from dewesoft then.
Going back to default value (<desktop>/<smarttitle>.pdf) fixed it.
It works now as it should and it's taking the file name as you showed in the video.
Thanks again for your support.
