Sending command with Modbus
I'm trying to read in from an instrument using the modbus plugin. The documentation for my instrument says "put the instrument into remote mode (a "1" command to register 100)." How do I send a "1" command?
Dear Michael,
thank you for reaching out to us. If you would like to send 1 to the register 100 you will need to add a channel under Coils with address 100 and size 1. Then in measure mode please add Input control and select Coils 100 and enter 1. I have attached images for additional explanation.
Kind regards.
Hey Gregor,
Thank you for the quick response! Looking at your screenshots I see you have a plugin called Modbus C, is that different in some way from Modbus M (the plugin I have)? I can't figure out how to tie the input control to a specific channel.
Dear Michael,
There is a difference between Modbus C (Client) and Modbus S (Server). The Modbus Client module will send commands to remote Modbus Server devices to read the data from their Modbus registers and will write this data to Dewesoft’s channels. There was a name change and you are using Modbus M (Master) which is now named Modbus Client.
In measure mode you add Input control and select the appropriate Coils channel, from the Channels list on the right side. If the display type of the Input field is set to Input field then you can simply write 1 in the Input widget - please know that you should leave the Design mode. In the attachment is a video on how I achieved this.
Kind regards.
I'm seeing now what I was confused about. When I add an input control I don't have the option of connecting it to any channel (modbus or otherwise). Is there a setting I need to change somewhere to make the input control functional?
Dear Michael,
you should be able to see the Modbus channel Coils 100. Do you have the channel Coils 100 set to used? Can you send us an image or a video of your setup or a setup file?
Kind regards.
Here you go, let me know if you need anything else.
Dear Michael,
I have used the provided setup file and connected it to my Modbus simulator (I have attached it). It didn't require much adjusting, just to establish the connection to the simulator. Then the value went through.
Please see the video.
Kind regards.
Hey Rok,
I appreciate the feedback. Unfortunately, as documented in the screenshot I attached, when I select the input control, I'm not able to assign a channel to it. I used that same Modbus simulator.
Dear Michael,
your attached picture is missing. Just to be sure can you check if the channel is ''used''? I have made another video where it is shown that if the channel is not ''used'' in the channel setup menu it does not appear in the measurement screen.
Kind regards.
I meant the screenshot in my previous post. The channel is used. It's all setup correctly per what your team has shown but still won't show up.
Could you send us the current setup file that you are using, so that we can check your settings?
Hello Michael,
Did you fix the Modbus issue? I'm having the same issue trying to add the coil to the input control.
I can see the coil channel in the measure window but when I select the input control the information from the coil channel doesn't appear.
Dear Richard and Michael,
could you please provide us with the setup file that is causing the problem?
Or make a screen recording of the steps needed to reproduce the problem.
Kind regards,
Rok
Hello Dewesoft team,
I have a follow-up question related to the topic,
Is there another solution for writing to a modbus channel with a higher frequency ?
I added the control channel writer add-in , and that works perfectly but as I understand it this has write frequency limits because it is built on the user control channel input feature ?
My application is I have an inclinometer signal which the DAQ receives, which I would like to pass to the PLC to be used for control of a motor,
This is a limitation of DewesoftX and not the Modbus plug in correct ?
Thankyou very much for your help , I look forward to hearing your ideas
Cheers
Jeremy
Cheers
Jeremy
Cheers
Jeremy
Dear Jeremy,
The limitation of Dewesoft is the Calc delay, because of the Windows OS, it is not real-time. The calc delay is usually 200ms.
The control channel writer can be set to output the value via Modbus on value change. It can be set as fast as you want, but there are limitations.
Due to the calculation delay, this won't be a fast control.
Best Regards.
Rok
@Rok Kmetič
Hi Dewesoft Team,
I am facing the same issue: I can see the HoldingRegister in the measure window but when I select the input control the information from the HoldingRegister doesn't appear.
The HoldingRegister is "Used" and "store". I am using Dewesoft 7.1.1.
Any idea how I could fix it? Is there maybe a newer Dewesoft 7 version to try?
Br Tobias Tobias
