Send periodic CAN message using user input
Good morning,
I’ve been trying to configure DEWE X so that, when introducing a value or pushing a button that is related to a user input button, Dewe will send a CAN Tx message periodically. The idea is to be able to send 3 different states of the same message (for example pause, start and stop) when Dewe is recording, the button will be placed in the personalized window. How can this be done?
Thank you.
Dear Francisco,
we don't quite fully understand your request. But as we understand it, we did a simple test setup file, which start periodically transmitting CAN data on "user channel" value 1 and stop transmitting on "user value" 0.
Regards
Good morning,
Thank you for the solution, I've been testing it and, the main problem I face now is that the message is sent at 1Hz but I'd like it to be sent at 500Hz, how can I change it?
Thank you.
Dear Francisco,
you can change the square conditions, in "TransmitPulse" formula, this will change the periodic rate.
Regards,
