Select Project File in Sequencer
Hello
I would like to create one single sequence that could be used of all of our testing ( we only have 4 different tests )
I am having difficulty getting it working. I would like to have a form block with a selection , however when I set this up with an if block after the form selection the system ignores the load project stage and ends after the if statement, however if i change the starting node to LoadProject , the project opens correctly
Any ideas would be greatly appreciated
Thank you very much for your help
Jeremy
After looking into it further ,
I found the issue was with my form and then switching on it using the if block , I tried with the simple user prompt option for yes or no and that worked then I retried the form and if switch with numbers , then numbers and spaces and then letter and letters and spaces. Then finally I retried with the longer form options and it worked !
I think my issues was some different value for the strings so it wasn't switching properly , the other thing I found was I had to be careful where i was and wasn't using quotation marks when comparing in if statements and then opening the project.
Thanks Dewesoft for an unbelievable software ! Its so great to work with and I only know very little of its capabilities so far
Cheers
Jeremy
