Selcet Directory in Data File Setup
  • Selcet Directory in Data File Setup
Patrick Cordes
Posted on 19.06.2019 11:31
Dear All,
in the new X3 SP6 and SP7 software i find that it is not possible to change the directory in which the data files are saved from the data file setup menu. It is possible to access the general prefrences from there and reset the default saving directory but a direct change of the directory from the data file setup is not possible. The given directory is grey and the field cannot be altered. The change over the default directory is rather cumbersome and is only a workaround solution. Is it possible to set the directory for data file storage directly? Any ideas why this isn't working?
I attached a screenshot to illustrate the problem (screen shot in german unfortunately..)
Thanks in advance for any support.
Patrick
Rok Kmetič
Posted on 21.06.2019 11:17
Dear Patrick,
this option was discarged because the direct directory altering was causing to many problems. We think it is not that big of a workaround maybe two additional cliks.
Rok Kmetič
Patrick Cordes
Posted on 21.06.2019 11:23
Dear Rok,
okay thanks fot the reply! Good to know that it is by design :)
Kind regards,
Patrick
