Reduce sample rate before/during export to txt file
I have recently performed a measurement. I have set the sampling rate to 200,000 Hz. When exporting, I wanted to reduce the sampling rate to 20,000 Hz. However, I cannot redact the column with the sampling rate. Is there a possibility to reduce the sampling rate?
Thanks a lot!
Dear Anil,
thank you for contacting us. DewesoftX supports exporting data to different file formats and the Export rate can be defined prior to exporting. Please refer to our online manual regarding the Export data to custom rates.
Would you please be so kind and provide us with more information regarding the issue. Which version of DewesoftX are you using? Could you send us a screenshot of the export that you are trying to achieve. Could you please send us some sample data file?
Thank you and kind regards.
