Rapid Voltage Change values calculated as NaN/zero in DewesoftX 2025.3 Power module
  • Rapid Voltage Change values calculated as NaN/zero in DewesoftX 2025.3 Power module
Lucian W
Posted on 23.02.2026 08:11
Dear Dewesoft Support Team,
I have a set of three-phase current and voltage data acquired with SIRIUS. I want to calculate Rapid Voltage Change values (du(max), du(duration) and du(dc)) using the Power module. After configuring the setup according to the manual (see attached dwsX-01-manual.jpg; my configuration is shown in attached dwsX-01.jpg), I recalculated the data. However, the results for Du_dc, Du_max, and Du_duration are all zero (see attached dwsX-02.jpg).
Is this caused by incorrect settings on my part, or is it related to the software version? How can I fix it?
Software Version: DewesoftX 2025.3 (RELEASE[PWR]-260109, 64-bit)
Lucian W
Posted on 05.03.2026 00:36
Problem solved — after updating to the latest version DewesoftX 2026.1 (RELEASE-260225, 64-bit), the Du_dc, Du_max, and Du_duration values are now calculated correctly.
It seems the issue was due to the older software version.
Lucian
Staš Jevševar
Posted on 05.03.2026 10:31
Great to hear your issue has been resolved! Don't hesitate to contact us again if some other issue comes up.
Regards, Staš Jevševar
