Problem with exporting LAFp to excel file
  • Problem with exporting LAFp to excel file
Jan Kazda
Posted on 14.09.2018 08:05
Hello, I have problem with Dewesoft V3 (it is through whole updates). When I am measuring audiosignal and want to export counted LAFp level to excel file in the file are only zeroes, but in Dewesoft it is displayed correctly. The LAFp level is measured offline from measured data, because I am using manual triger and wanna to analyse only part between triggers. Any help what to do, please? Thank you for your help.
Jan Kazda
Posted on 14.09.2018 08:27
As I try now the problem is with exporting into *.txt file too...
Jernej Sirk
NVH Application Engineer
Posted on 14.09.2018 08:42
Dear Mr. Kazda,
can you please send us the data file you are trying to export to support@dewesoft.com?
Thank you and best regards,
Jan Kazda
Posted on 14.09.2018 09:05
@Jernej Sirk I am so sorry, but I am afraid it will not be possible, because it is confidential data from automotive. Will be another way how to help you without sending whole measured data file? As I tried export from raw measured data is working in any cases, but when I recalculated it first offline export is incorrect.
I am using DEWE 43-A unit and DEWESoft X3 SP2 (RELEASE-180426) (64-bit) (but in sharp version is the same problem)
Jernej Sirk
Posted on 14.09.2018 09:17
Do you see the same problem if you use the function Copy data to clipboard.
And then paste the data to Excel.
Jan Kazda
Posted on 14.09.2018 09:43
@Jernej Sirk Thank you for your help, but this function does not work with me. It show this window with any problem.
