Power analysis missing data
I have a recording (with full rate data) done with the Power Analysis plugin. When looking at the data offline I notice I am not able to see the calculated values (e.g. harmonics in attached screenshot) even though the high speed data is available. Do I need to be connected to the Dewesoft slice with the power analysis licence for this to work or am I doing something wrong?
thanks
ed
Dear Edward,
thank you for reaching out to us. If the file was recorded with the Power Analysis plugin you do not need to connect to a device since the license is written to the data file. Would you please be so kind and send us a data file? You can send the data file to [email protected].
Kind regards.
Please send us a data file that you analyzed using the Source Analysis plugin. We will help you check and find the cause and how to fix this problem. flappy bird
