Pink Noise in Math mode
Patrick Cordes
Posted on 15.12.2020 06:45
Dear Dewesoft Team,
is there a way to use pink noise in the math mode? Szenario: I have one analog output and want to use the function generator to output pink noise (easy). BUT I want to filter the pink noise first. In MATH mode I know there is a noise signal. Is there also a pink noise signal? Or could you provide the filter settings I would need to make the noise signal in MATH (I assume is white?) pink? Or is there an easy way I am missing to apply a filter to the output signal of the function generator?
Any Input is appreciated.
Kind regards,
Patrick
Primoz Lapi
Posted on 16.12.2020 14:36
attached is a setup where the pink noise is filtered out of white noise with formulas.
I hope this helps.
Patrick Cordes
Posted on 18.12.2020 12:57
thank you that was what I was looking for.
Patrick
signup
for
free
account
