Photron FastCam Link
John Xing
Posted on 31.08.2018 09:36
When I check the Photon FastCam box under the hardware setup page on Dewesoft 7.1.1, Dewesoft prompts the following: "PDCLIB.dll library not found".
Does anyone know what this means?
Urban Baš
Software Test Engineer I
Posted on 31.08.2018 09:59
This means you don't have the PDCLIB.dll in your addons folder. Did you install all extensions when you installed Dewesoft?
John Xing
Posted on 31.08.2018 10:24
@Urban Baš
I was recently given the system I do not know the details, I am assuming that the add-on was not installed. How do I go about obtaining the extension for this system?
Urban Baš
Posted on 31.08.2018 10:33
In the attached .pdf you can find the instructions for the plugin. You need to contact our support (support@dewesoft.com) to get the missing dll files, but you must have a license for the plugin.
John Xing
Posted on 31.08.2018 10:39
System came with a license key, would I have to check with support to see if the key I have is good, or would I be able to find out just by installing the plugins?
Urban Baš
Posted on 31.08.2018 10:44
Yes, check with support if the license key supports the plugin.
