Personalize screen
Carlos Polvorinos
Posted on 28.03.2025 16:28
Is it possible to change the font size and typeface in 2D tables when they are displayed on the screen? I don't see any options in the menu on the left side. Even if I change the size of the table, the font size does not change.
Regarding 2D graphs, is there any way to set maximum and minimum Y-axis value? And make the X-axis values start with 1 instead of 0? And change the size of the axis numbers? I don't see any options in the menu on the left side.
On the display screen, is there a way to put it in full screen? removing the top part of start, freeze, stop, store, etc?
Kind regards,
Carlos
Hana Prtenjak
Posted on 31.03.2025 12:54
Dear Carlos,
Currently, there isn't a specific option to change the font size and typeface for 2D tables directly. However, you can adjust the overall font size by going to Options → Settings → User Interface → Font Size. This will change the font size across the software, including the 2D table. Similarly, this method can also be used to adjust the size of axis numbers for 2D graphs.
Regarding the 2D graphs, yes, you can set the minimum and maximum Y-axis values by manually entering the desired number for the Y-axis. The same applies to the X-axis, where you can set it to start from 1 instead of 0 by entering the value you want. I’ll attach a video showing how to do this.
Lastly, to enter full-screen mode on the display screen, you can press Ctrl + F to enlarge the active online display screen to the full Dewesoft X window. To exit this mode, simply press Esc or Ctrl + F again.
I hope this helps! Let me know if you have any further questions.
Robin Faubel
Posted on 24.04.2025 20:15
On the topic of personalization, is there a way to rotate the y-axis values so that they are horizontal instead of vertical?
Hana Prtenjak
Posted on 25.04.2025 12:53
Dear Robin,
At the moment, there are no plans to change the orientation of the y-axis labels. We currently display the text vertically to allow for more content to fit clearly within the available space. This approach helps maintain the overall readability and layout consistency, especially when dealing with longer labels.
We really appreciate your feedback, and we’ll definitely keep it in mind as we continue to improve the software.
