PASTE S/N SENSOR IN ANALOG CHANNEL
  • PASTE S/N SENSOR IN ANALOG CHANNEL
antoine janvier
Posted on 06.06.2024 10:04
we have a lot on sensors in our laboratory (nearly 8000 sensors)
we are actully doing a big sensor database to make it easier to configure big measurement
the problem is that we cannot copy and past in the S/N (even for one line) we have to clic on the scrolling menu and select
is there a way to past all the S/N sensor in one clic to make it easier than selecting every sensors one by one?
what is strange is that if we copy one line on the analog panel directly in a a Notepad and add a sensor number (already known by the sensor database)
with excel (in .xml)
and then past it in the analog channel, the software find the sensor and write all the good parameters (sensivity, scale, full bridge, etc..) but not the S/N Number
and we can only do this line by line, i didn't find a way to copy all the configuration of the analog
BR,
Antoine
Rok Kmetič
Posted on 07.06.2024 11:01
Dear Antoine,
with the copy-paste function, the serial number of the sensor cannot be copied.
If you have a large database of the sensors you can import the sensors into Dewesoft.
This will open a new window where the senses can be manipulated. Please see the attached video. The steps required to import the sensors can be found in the F1 manual: https://manual.dewesoft.com/x/options/editors/analogsensors
I hope this is useful for you.
Best regards.
Rok
