parallel installation of X3_32bit and X3_64bit
  • parallel installation of X3_32bit and X3_64bit
Stefan Jaik
Posted on 22.03.2019 12:30
Hi, i want to install 2 different X3 Versions on my PC:
First i installed X3_sp4_32bit in c:\sw\Dewesoft. Then i tried to install X3_sp6_64bit c:\sw\Dewesoft-Test, but this didn't work -> see error message.
Is this somehow possible?
Posted on 22.03.2019 14:17
Dear Stefan,
unfortunately, only one version of Dewesoft can be installed. You can install a 32-bit and 64-bit version in parallel but they must be the same version ( e.g. SP6).
Regards
Stefan Jaik
Posted on 25.03.2019 09:41
Hi, I am a little bit confused.. our Dewesoft sales agent reported he was able to install X2 and two different X3 Versions (see screenshot).
Posted on 25.03.2019 14:27
Dear Stefan,
this functionality was a little change because the new versions come only with installer and not in binary files anymore. The installer checks if there is a older version installed and if it is, you can not install the new version. But with SP4 you can have both versions, but you need to install the SP6 version fist and then the SP4 version, which do not "check" if any Dewesoft version is on the PC. If you will have troubles with the installation we can arrange the Team Viewer session.
Regards
