Order Tracking - Time Domain Harmonics Coarse Steps
I have a setup file that I use for conducting order tracking on vehicles. I recently collected data using DEWESoft X6 and have an issue with the time domain harmonics having a coarse step size. It appears that the harmonic values are only being updated every 0.5 seconds. When I used this same setup in previous versions of DEWESoft the update rate for the time domain harmonics matched what was specified the settings. I have two screenshots - one showing the current refresh rate and one showing how it used to appear.
NVH Application Engineer
Dear Andrew,
the results from OT module are updated on RPM change or updated each time interval.
If you have changing RPMs we suggest using only the Update on reference change option. The smaller the Delta RPM, the more frequently the FFT results will be updated.
I have it set to update on time interval, with the update rate every 0.1 s, but it appears to only update every 0.5 s.
Dear Andrew,
sorry for the late response on that matter.
May I ask you which version of Dewesoft are you using when experiencing the issue?
Would you be able to send us a data file for recalculation?
Jernej,
Our local representative in the U.S. was able to help me with the issue. I've attached an email in a zip file that shows the solution they provided.
Thank you,
Andy
