Order Tracking Export Rate
I have a setup used for determining the vibration orders for an engine. As part of this work I export certain orders in the time domain. These are generated using the Time domain harmonics option in the Order Tracking setup. I have it set to update every 0.1 s. In DEWESoft versions prior to 2021.5 if I exported the results, the export rate was 9.9 Hz (asynchronous). After I updated to DEWESoft 2021.5 the rate changed to 2.6 Hz. I cannot figure out how to change the export rate back to the original value.
Dear Andrew,
thank you very much for contacting us. This seems to an issue. We have already reported the issue to our developers and will get back to you as soon as the issue is resolved.
Kind regards.
Dear Andrew,
we would like to inform you that the bug was fixed in the release candidate version of DewesoftX RC-2021.6. The fix will be included in the Official Release of DewesoftX 2021.6.
Kind regards.
