Order Tracking Error
Benji N
Posted on 03.12.2019 16:10
Hi!
I do not know why I get this Error (See pic below)?
My sample rate is 3000Hz. For this OT setup I only need 1600Hz in sample rate and not 6400Hz. (6000rpm/60)* 8order = 800Hz.
Jernej Sirk
NVH Application Engineer
Posted on 04.12.2019 08:43
Dear @Benji N,
The MIN required sample rate is calculated from the Max order in Settings.
If in the Order tracking setup you select the order that is smaller than in Settings, it takes the value that is defined in Settings.
So if you go into settings and select 8 and Max order to Analyse, you will not get an error anymore.
Jernej Sirk
signup
for
free
account
