Online/Offline math operations + Export
I am doing some post processing on my data in dewesoft. The 'Recalculate' function works fine, but the recalculation for some of the math operations are not updated for some others between each triggered event. As in the attached image, the one with a dash is an example of where its doesn't update. Therefore, when I export to .mat format, it is only exports a single value instead of a full array of values which it should be.
I suspect its related to the Online/Offline/Calculation function under the Math Tab, but Im not sure what the problem is.
Hi Ava,
I believe it can be related to the Math functions you have chosen. Can you please send me the data file you have, so I can take a close look to it and answer you completely then? Also it would be great if you can describe what exactly do you want to get - is it only full array values instead of single?
Have a nice day,
Nina
