Not Stored Display Error
Steven Hardy
Posted on 01.03.2023 11:08
Hi. I've got a simple data acq. setup where some channels are calculated live and the high rate raw input is not stored to save disk space. On the data review screens the Date and Time are displayed in the usual digital meter widget - now overwritten with the words 'Not Stored' which makes the date/time partially unreadable - and they are stored?! Anyway of disabling this error?
Steven Hardy
Posted on 01.03.2023 11:12
Example screen - 2 channels not stored, 2 stored but date and time displays show not stored.
Matic Pevec
Posted on 07.03.2023 12:47
Hi Steven,
I understand that you use Digital meter for presenting some system parameters, date and time for example. Digital meter can be set for system parameters either by a channel is assigned to the digial meter or not. If you click on the digital meter you will see whether any channel is assigned in the background or not. on the right hand side.
The "Not stored" channel is assigned to the Digital meter in the background. If you click to Digital meter you will see assigned channel as highlighted on the list on the right hand side.
None channel is assigned to the Digital meter so "Not stored" watermark is not present.
In order to solve your problem you can either unassign channels and "Save" DXD again or modify DXS setup file for all the future measurements.
If you have multiple DXD files that are already stored you can modify them all by "Offline math and displays" in Apply Action module: https://manual.dewesoft.com/x/analyse/postprocessing/applyaction
