Multiple monitors support
Rudi Stolk
Posted on 13.11.2013 12:11
For a laboratory setup we would like to use the Multiple Monitor feature in Dewesoft X, SP2. The computer runs on Windows 7, 64bit and has two Quadro 2000 videocards.
I have three screens and am able to use them all usinig the 'attach monitor' command in display properties. On the primary screen I've controlbuttons which I setted to Dewesoft Action 'Screen select'. The purpose is to change the displays on the 2 secondary monitors, on which I subsequently attached the screens. Is that possible and meant by the devellopers? What I see now is that on all of the 3 screens I push the 'screen select' button, the action (change screen) is always excecuted on the primary screen.
Another thing I would like to mention is that the screen layout on attached monitors does not update when it is changed on the primary monitor. It updates only when you attach the monitor again.
Thanks in advance!
Regards,
Rudi
Thanks in advance!
Regards,
Rudi
Rudi Stolk
Posted on 15.11.2013 09:09
Hello Dewesoft support team,Can you give any information about this subject?
Thanks!
Rudi
Thanks!
Rudi
Marjan Grilj
Posted on 15.11.2013 09:12
Hello Rudi,
I sent info on behavior to the developer, i'll keep you informed on the progress.
Best regards
Best regards
Rudi Stolk
Marjan Grilj
Rudi Stolk
Posted on 19.11.2013 11:06
Thanks for your reply, we look forward to the fix!
Regards,
Rudi
Regards,
Rudi
Rudi Stolk
Posted on 04.12.2013 16:41
I would like to add something to the above mentioned issue: the screen-select action does not work anymore in stored recordings. Can that also be fixed?
Rudi
Rudi
signup
for
free
account
