Modal Testing - Show default in Compliance instead of accelerance
Hello together i have question regarding Usabiliy.
When we measure with modal test we mostly are interested about the compliance (in µm/N) of the system, but in Dewesoft, since we measure the acceleration, we get the accelerance --> makes sense obviously.
My Question would be: is there a possibility "preselect" that there will be result shown in compliance not the accelerance ? --> Yes i can double integrate in the frequency domain and get the same results. But it is very time consuming to select all the points, needs a lot more and space is saved.
Aswell as small adjustments in the Setup makes you use it again.
My suggestion/Question would be.
- Can there be a button on on the left side of the Screen (where you select x axis or y axis scale) to choose which view you want?
--> Some like dynamic stiffness over compliance and so on. Should be "just" one button to choose from, what view you want, but saves a lot of time.
--> or is it possibile to create a template that copies it, so it is easily usable?
2. Please work on the selection of signals you want to view. Especially when i do a modal analysis, i want the FRF for multiple Curves (sometimes all, or just all in x direction...) But with Dewesoft i have to hand select each an everyone, by hand, which is really annoying and keeps from thinking of the problem, because have to take care i click on the correct row 24 times.
3. Additionally: Can 2 diagrams be "linked" somehow together? If i want to view an FRF, i obviously would like to see phase and coherence of the same point. --> Now handselect for each graph aswell .................... really unproductive and time consuming. --> This could be applicable for other views aswell, that they refer to the same underlying data.
Best regards
Daniel
Dear Daniel,
thank you for reaching out to us and for your kind feedback. I will forward this feature request to our developers and will keep you updated.
Kind regards.
Dear Daniel,
I would just like to double check something. From the image you attached regarding the compliance: Would you like to have an option to select the compliance just for the animation? Or you would actually like to select compliance in Modal Test which would actually create the channels?
EDIT: spelling
Kind regards.
@Gregor Šmit
I would like the possibillity to view my Transfer Function (in Picture marked as (2) ) in the 3 / or 6 possibilities shown in the other picture.
I have seen that in the Modal Circle there is already the possibility to view it in accelerance Mobility and receptance. in the picture shown as (1) -->
I: i would appreciate it, if i could select to view my Transfer Function in a dropdown menu aswell, to view it those different domains .
--> "basically" just copy the funtion from the modal circle
--> ( (m/s^2)/N (mm/s)/N (µm)/N ) ) at best you can select the scale if it is like mm/N or µm/N
II: It would be great if two graphs could be linked to view the same underlying data.
--> If i want to view the FRF of Point 3. , i would obviously like to view the Amplitude and Phase of the same point.
--> As of right now, i need to select the correct point twice (or 3 times) in the FRF, Phase and coherence which is just a waste of time, and annoying.
Best regards
Daniel
