Missing Header in Report Screen and missing Text Label in newer DewesoftX Version
i actually want to generate a Report for printing after a Dewesoft measurement. So i selected the Report Screen where i can select A4 Landscape format etc. but i miss the integration of an header where i can display date and time of the measurement file. Is there any possible way to integrate that? With Text-Label i can only display the Measurementfilename.
The next thing is when i update from actually used Version 2021.6 to the newes one, i miss the Text-Label Widget so i can not use the actuall Software without changing the whole project.
Best Regards,
Florian
Dear Florian,
You can use day and time option in the report if you add "Digital meter" widget and configure it in order to present day and time. See a referenced screen shot what I'm referring to.
Regarding the TextBox widget I can inform you that we updated it to a completely new version which has many more options. You can refer to the manual https://manual.dewesoft.com/x/measure/displaydesign/viscontrol/textbox. It describes "Expressions" feature which would fit to your need in order to present day and time.
However if you don't like the newest features you can use the old version, which can be enabled in the Settings by "Enabling old text box widget"
Best regards
