Missing Excitation Channel in Modal Test
Im am using Dewesoft X3 SP9 (RC-191007) ,befor i use SP3 .Now i am Missing the Excitation Channel in Modal Test
NVH Application Engineer
Dear Mr. Geiger,
Can you please give us a little more information about this behaviour? Does this happens in Measure or Analyze mode?
Can you share a screenshot, setup or datafile?
It happens in Measure Mode
@Gerhard Geiger
Are you reffering to the channels in the attached picture?
This Channel is missed since SP9
These channels are available if Roving hammer/response is selected in the setup.
If Roving is not selected (you only measure in one group) these channels are not needed.
Here you can see the Exitation Plot i want have with Impact Hammer without roving Hammer
Dear Mr. Geiger,
The easiest way is just to select Roving hammer in the setup. This will have no impact on your existing setup,
but you will be able to see the channels that you want.
In the Measure, right click on display to generate updated display which you can modify freely.
