Measurement between two cursors
  • Measurement between two cursors
weizhao zheng
Posted on 12.10.2018 08:50
Dear Sir or Madam,
is it now possible in dewesoft X3 to show the values (e.g. RMS, Min., Max., ... etc. ) between two cursors live in "Analyse" mode (just like what the other oscilloscope can)? I do not want to use the Math formula and recalculate the values every time. The values/formulas provided by "Info channels" are not enough.
Thanks in advance!
Posted on 15.10.2018 09:18
Dear Weizhao,
unfortunately, this feature isn't possible in X3. This request is already on the wish list, we will notify you when there is an update on this issue.
Regards
weizhao zheng
Posted on 15.10.2018 09:27
@DEWESoft Support
thanks for your feedback!
Jake Smiley
Posted on 21.06.2023 17:44
@DEWESoft Support
Is there a method to see average/rms/other statistics based on a viewing area within a recorder and/or between cursors? Using the math statistics block does not work well when looking at many different sections throughout a data file (have to recalculate with new time range each time)
Gregor Šmit
Posted on 22.06.2023 10:19
Dear Jake,
thank you for reaching out to us. Our developers are working on implementing this feature. For now a workaround would be to use Basic statistics single value math and zoom to region or by using the cursor module.
Kind regards.
Werner Wild
Posted on 14.07.2025 14:15
Hello Dewesoft Team,
are there any news about this feature request?
Does the measurement of max, min and RMS values between two cursors now work?
That would make my life a lot easier ;)
Kid regards
Gregor Šmit
Posted on 18.08.2025 10:23
Dear Werner,
we would like to notify you that processing markers are available as experimental feature in DewesoftX 2025.2:
please make sure that markers are also enabled during installation.
Kind regards.
David Dahlgren
Posted on 11.09.2025 12:57
Thank you for this. Very much needed.
How ever, something very important is missing.
If i have multiple rows with measurements. Of course the markes should go over all the rows in the recorder!!! Not just one.
For example here: I want to now the average effiency when the pressure is 50 bar... but the markes will only calculate on one row!!!
I experimented by putting multiple variables in the same recorder, but it didn't really work.
Gregor Šmit
Posted on 16.09.2025 07:37
Dear David,
thank you for the feedback. We have created a feature request for this and will notify you wen it will be implemented.
Kind regards.
Gregor Šmit
Posted on 02.03.2026 08:44
Dear David,
we would like to inform you that the feature request to support multi input on time span marker was implemented in DewesoftX 2026.1. When adding the marker on recorder please press CTRL+ALT and the marker will be added to the whole Recorder group.
Kind regards.
