Matlab Export
I have recently exported a bunch of .dxd files to .mat files. The .dxd files contain a large number of triggered events, however when I export to .mat files, its seems as if only the very last triggered event is exported (and yes, I have it all zoomed out as to export everything). But when I do the exact same export on the same file to excel format, every single event is exported.
The size of my .dxd files are around 1.5 GB.
Any idea of why it wont export everything into .mat?
Hi Ava,
Can you please send me a screenshot of settings in File export ?
Does ''Ignore gaps between triggers'' solve the issue?
Best regards
Matic
I have attached the settings I've used so far. But yes, ticking the 'ignore gaps between triggers' did include all events. But is there a way to make them independent of each other already in the export from dewesoft? i.e. to store each event in its own variable?
I'm sorry, I'm not sure I understand what you meant to store each event in its own variable. Can you explain it?
Best regards
